how to change impeller 1998 evinrude 115
Silvertip
Re: how to change impeller 1998 evinrude 115
Any major work on your engine should not be attempted unless you have an engine specific service manual. I don't know of any on-line sources that would provide the detail you need. The process involves disconnecting the shift linkage, removing the bolts (including the one under the trim tab) and dropping the lower unit. The pump is at the top of the lower unit.
JB
Evinrude Troubles topic.<br /><br />You can buy a manual online from many places, MLA.<br /><br />Don't work on an outboard without one.<br /><br />Good luck. :)
