How to change Spark Plugs
bengaltiger14
I have Mercruiser Bravo 3 5.0L MPI. Is there an easy way to change these spark plugs? I cannot even get my hand to the #1 spark plug because it is so tight. Is there a trick to this?
bengaltiger14
Re: How to change Spark Plugs
Ok. So basically I should just suck it up and shove my fat arm down there.
Don S
Some boats with a 5.0L Mercruiser you can see all the plugs and it's a 10 minute job, there really are some that you have to pull the engine on. One I used to work on took 5 hours to get the engine out. Putting it back in took longer. The boat design engineers could care less about maintenance.
Ayuh,.... Welcome Aboard,... It's either that or remove some of the pieces, 'n parts that are in yer way....
Capt Ken
If you remove the cooling hose that goes to the bottom of the manifold and let it drop out of the way, you can get to the plug.
