0A992052 6Hp.What is the proper way to check Bleed system and check valves? Fuel system/ powerhead.
M Mi duckdown Commander Joined Apr 14, 2007 Messages 2,575 Aug 18, 2012 #1 0A992052 6Hp.What is the proper way to check Bleed system and check valves? Fuel system/ powerhead.
M Mi duckdown Commander Joined Apr 14, 2007 Messages 2,575 Aug 19, 2012 #2 Re: How to check bleed sytem bump
Faztbullet Supreme Mariner Joined Mar 2, 2008 Messages 15,931 Aug 19, 2012 #3 Re: How to check bleed sytem Unplug the bleed hoses one at a time from under carbs while running, you should have a fine mist like from paint can from valve. If clumps,spitting or dribbling out valve needs cleaned or replaced.
M Mi duckdown Commander Joined Apr 14, 2007 Messages 2,575 Aug 19, 2012 #4 Re: How to check bleed sytem Thanks Fazt. will respond after investigation.
