how to check fluid in tilt n trim????? thank you
junior1113
new to boating tilt supposed to be in the up position???
ezeke
Re: how to check fluid in tilt n trim????? thank you
With the boat level, tilt the motor all the way up and support it with the trail locks. Remove the fill plug and add fluid until it reaches the bottom of the hole and begins to run out. Replace the plug, release the trail locks, and cycle the engine up and down several times. Repeat as often as necessary until you can no longer add fluid.
