Re: How to check water pump on a 2hp evinrude?
on mine, it does blow small droplets out those little relief holes. Can be hard to see, but if you hold your hand in front if it, it gets wet. I changed the impeller on mine (eventhough it did seem to pump water), it pumped quite a bit more after. It's such an easy job to change it, you should just do it if you're at all worried about it's condition, or you don't know if/when it's ever been done before.
