How to correctly charge 24v setup?
Tealc11
OK so everyone helped me set up my 2 12v batteries into a 24v setup.:)
But as I was hooking everything back up I found a new dilemma.:eek:
I have a onboard charging system that came original on the boat -- 2 red and 2 blacks leads that were used to charge the 2 batts in the old 12v system.
I now have a 24v TM and have setup the 2 batteries in a 24v setup.
My question is Do I hook up the 2 reds and 2 blacks to each battery and overnight charge --- or Do I connect the red to batt 1 and the black to batt 2 and charge the whole system similiar to how it outputs the voltage.
I didnt want to blow something up --so better to ask before I proceed;)
fishrdan
Re: How to correctly charge 24v setup?
Check out my reply to your other thread about wiring 24V to the TM.
Silvertip
You connect the outputs to each battery just as you did in a parallel system. Grounds on these chargers are isolated from each other so the series battery connection presents no problems.
