How to cover gimbal housing
No Worries
Finally got around to removing the out drive for the winter. As a first time boat owner I'm curious as to how everyone covers the exposed area after removing the sterndrive.
GA_Boater
Since the one Shaw linked to is discontinued and sold out for Mercruisers, a plywood plate can be used just as effectively. It doesn't need to be pretty and some foam can be glued on for moisture and bug control.
Ayuh,..... Welcome Aboard,..... I don't,.....
There ain't much there that can be damaged over the course of a couple months,.....
If yer that anal 'bout it, duct tape a sheet of plastic over it,...
No Worries
Thanks for the welcome Bondo. I looked in there and had the same though as you but...it's gonna be a good five or six months up here in Michigan.
shaw520
Agreed,... but I try to make it harder for critters to get in over the winter storage,... I put buckets of moth balls around for the winter but remove come spring bc I hate the smell,.. but apparently so do the mice bc since using them I havnt had any critters. About 10yrs ago I had (I think) a chipmunk get into my 220 SRV,.. made one hellava mess of the wiring in my dash.
fishrdan
I tied 3-4 plastic shopping bags over the gimble housing, not much protection from critters and such, but will keep dirt and water off everything.
No Worries
For now I put a dryer sheet (critter deterrent) in there and duct taped a folded contractor bag over the whole thing.
wrench 3
I agree that nothing in there really needs to be protected. So I just stuff a greasy rag into the drive shaft bellows.
