How to determine which drive I have
delta1
1993 Bayliner Capri 1850 4.3lx
The drive has this serial number: DF040053
Any chance one of you guys have a way of determining if this is a Alpha One Gen II ?
As always, thanks for the help,
Paul
PS I'm am ordering a transom seal kit for this drive, I noticed that the Alpha One gen I, has only 4 holes in the seal where the upper mounts to the bellhousing. The original gasket on my has only 4 holes, but I noticed that there is a hole between the studs that match up to a spring loaded check ball on the upper drive. Did the po mess up on an earlier repair and put the wrong seal in it?
Don S
Re: How to determine which drive I have
It's actually 0F040053 Not DF and it's an Alpha I Gen II outdrive.
That gasket having the extra hole doesn't hurt a thing, and will work on either.
delta1
Don,
You are amazing, always willing to offer accurate help.
Thanks again,
Paul
