This is a volvo AQ125A with the single solex carb. Tried to start for the first time this spring 2 wks ago only small amount of fuel seen at carb. Meanwhile I repaired the starter problems I was having so only got back to the startup tuneup today.
Starter cranks fine but engine won't run. I inspect the carb and no fuel going to bowl despite however i tried to pump it. I pulled the line from tank to fuel pump, inserted a bulb like used on outboards, and I got good gas flow up to the fuel pump. Again tried to start using throttle, with same result, but now I know fuel is flowing to the fuel pump. I then slightly loosened the fuel supply line attached directly to the carb, and immediately got a good spray of fuel there so the line is working fine up to the point where the fuel enters the carb.
Is there any thing else I should do before removing and rebuilding the carb?
No fuel supply probs all last season and when I winterized it in the fall no problems starting it up or anything either.
How hard is a carb rebuild since I have never done it before?
Where is a good place to fine the rebuild kit online...noplace stocks these volvo parts near me!
Thanks,
Joe
Thanks,
Joe
