I'D RATHER B FISHN
- May 5, 2009
- 70
I have a 1989 Suzuki DT115 that I just recently purchased with a boat. I took the boat out and it ran terrible. Would not rev up. So I started checkin the fuel system & Carb's. The Carb's were terrible. Looked like someone ran wet sawdust through them. Hopefully that will do the trick. I have not tested the oil injection system, but would feel better if I just disconnected it and mixed the oil fuel ratio (50:1) myself. Does anyone have the step by step process that I need to perform to complete this task. I have pulled the sensor out of the oil resevoir, pulled the hose line off on the oil resevoir, & removed the tank from the engine mount. What else do I need to do. Thanks for all of your help. P.S. this is my first iboats. forum post.
