how to disengage the out drive
J JACKSON
i have a friend that has a 1985 Sunbird with a mercruiser io 4 cylinder 140hp i think. how do you disengage the out drive so you can just throttle the engine there is no button in the middle of the shifter. i can post pics if needed tomorrow and get the serial number
thumpar
Re: how to disengage the out drive
You should be able to pull the control toward the center of the boat then rev the engine. On mine I have to pull on the pivot point as to not put too much leverage on the whole control assembly.
