Keith Buchanan
- May 10, 2004
- 221
1989 50 HP 3 cyl.<br /><br />Hi guys, after gear failure I have undone everything on the gearcase, removed the gear shift shaft and pump housing and still the driveshaft and propshaft will not pull out. I presume the crank driveshaft has to come out before the prop shaft will move. Is there a trick to get these out.<br /><br />Regards Keith B...
