I just bought a 78 115hp seahorse. Good even compression 95 to 100. I just got the tilt working, there was a little water mixed in with the fluid so I flushed and filled it and it works well.
I want to test for spark but I wanted to change the lower unit oil first. I read in the faqs that you fill from the lower drain hole??? Any tips for accomplishing that? Also, what type and weight oil to use? So far so good, the lower unit oil had no water or metal in it.....Thanks again... BTW, Manual is on the way EDIT: What keeps the drain screw from vibrating out???
