I just had my friendly nearby yamaha dealer install an engine (95 yam 225) on my boat (91 ski centurion falcon). It was exactly the same overall dimensions as my old engine (91 yam 225) but for some reason they decided it would be better to mount it one notch higher on the transom. You guessed it...cavitation. Anyway, this nearby dealer ain't that nearby, so I decided to fix it myself. I hoisted the engine and began loosening the 4 mounting bolts. As the sealant started to break loose, brown liquid slowly trickled from the transom holes. How awesome. Apparently these monkeys put this engine on and silicone sealed it, without removing any of the old sealant. Luckily they put the bolts in the wrong holes, or I never would have known. This boat has only been run about 5 hours in this condition, and there doesn't appear to be any real damage. There was some wet sawdust that came out with the bolts, but no big chunks, and the holes are still round. One interesting thing to point out is that the 2 lower bolts had no corrosion on them, but the two upper ones did.
So what is my next move? Should I just replace the hardware, put a good seal on it, and call it good? Is there something I can do to shore up my transom, in case it did get damaged?
