ShoalSurvivor
- Aug 1, 2012
- 233
Flapper broke off and 1/2 is stuck in-between the Y and the separated section of the pipe, just before the upward bend.
I can move it freely about 4" farther back from where it is now, but it is too wide to get any further past that, either way.
Vacuum - nope!
Long flexible grabber - nope!
Sheer will power - hope!
push with plumbing snake - nope (yes, very carefully navigated into the pipe, so as not to injure or even touch the bellows/bell housing.)
Hmm.. maybe some lube???? Is WD-40 safe to spray into the pipe? Other choices?
My wife can reach it from the top, but can't get a grip on it and she was not able to get mini pliers on it...
Maybe a 1/2" copper tube, bent, will get the force needed to push it from the aft?
I really do not want to pull the housing bell for a number of reasons... but as a last resort, I could probably grab it with a pair of super long needle-nose pliers and yank it through. (but I would not yank it though the bellows).
Any other ideas?
Thanks!
Vacuum - nope!
Any other ideas?
Thanks!
