How to get part number for Volvo sx drive?
320Busdriver
Trying to determine the exact part number for my drive to get the cost of repairing u joints. Local repair shop says might not be able to determine until the drive is pulled and number from shaft assy is read off it. Some allow for replacement of spiders and some mandate entire shaft assy(rockwell @500$). I have serial numbers for both the engine and drive itself but nowhere do I see if its a sx a,c, m1, mtd, r,s etc...lots of sub designations..any help in running down what kind I have and what my repair options are , if I have any, would be great.
Is there a product plate info decal on the drive itself? if so where. I have to drive 25 minutes from home to the boats location.
320Busdriver
Thanks for that FT
vessel SN is GFNMA 637D505
Engine model# 3869255
SN 4012158430
Drive model# 3868891
SN 4202142931
transom plate model# 3868844
SN 4151094777
Will head out to lake to inspect plates for further designations
320Busdriver
Its a 05 FW 210H.
I got the numbers off the drive:
its an SX-M Ratio 1.60 and product number is 3868891. This should help.
I found 3860842 which is entire assembly for 499.00
spiders are 3850812 and 112.00 each..
seem about right??
looks like there are two possible shafts in it. My first post was wrong...The rockwell, which can have the spiders replaced separately, or the GKn which lists the spiders as "not sold separately"
Guess which one I'm sure to have??
Fun Times
Its a 05 FW 210H.
seem about right??
Cool, now that you have found your numbers it looks like you're on your way at finding parts as that was your original question.:encouragement::eagerness:
I was going to mention you could input either one of your numbers into the top area of this link to help find parts for "your" drive, etc., https://www.volvopentashop.com/epc/...020?path=MarineDrivesAndTransmissions/7746020
Looks like you're on track but here are a few past topics for what you're about to go through with U-joints,
https://forums.iboats.com/forum/eng...-volvo-penta-sx-m-u-joint-spider-part-numbers
https://www.google.com/url?sa=t&rct...t-which-path&usg=AOvVaw1Cbu1hmQDzpZItrBMh4KtZ
https://forums.iboats.com/forum/eng...9969268-up-date-sx-m-vibration-finally-solved
Also search online Volvo Parts Bulletin Group Number Version P-44-1 5 02 if needed.
Good luck.:encouragement:
