jayhanig
Master Chief Petty Officer
- Jun 27, 2010
- 836
The temperature sending unit on my 1985 GM Mercruiser 120HP I/O is apparently bad. The gauge just sits on zero even after the engine is warmed up. Grounding the sending unit pegs the temp gauge to the hot side, so the gauge itself is apparently good.
So I tried to remove the sending unit today without any success. I probably made it worse. There was a center post that the tan wire attached to that had flats behind it but putting a wrench on it just spun it within a larger fitting. The larger fitting is made of brass and I couldn't budge it, even using a cheater bar. What I did manage to do is chew it up a little. I switched from a 12 point socket to a 6 point impact socket and it slipped off also, chewing up the flats a little more. Finally I got out the lockjaw pliers and chewed it up a little more before I gave up. It's not chewed up beyond all redemption but I wanted to stop before I got it to that.
Ideas?
Ideas?
