i just bought a boat and it has a fish well and bait well installed. I wanna tackle the fish well first. Its basically got two holes in it. The one on the top doesnt have a pump attached but is hosed to the through hull fittin on the transom below the waterline. The hole on the bottom has a pump that drains the water out and is hosed to the through hull fittin above the waterline. Is this set up correct? While i can drain water by pumping it out, How do i fill water?
