raptorzx7r
- Jul 21, 2011
- 9
just bought a sea pro renegade, jet boat, looks very much like a seadoo to me, apparently it use to be powered by a force 90hp. it was replaced by a 4 cylinder of which i was told it is a force 120. the boat was a 1994 model. what all has been changed to get this engine in i am unsure of. the problem i have is it punched a hole into the block when a rod broke. i can find NO tags on the engine to identify it. i keep reading of mercury force, force engines, are they the same? i did find an older 1990 force powerhead for sale online, the pictures of certain parts like the coils, the mounting, cdi all look different, then i located a mercury force like a 1996 i think, and it looked like what i have. the 1990 is one to be sold as parts for rebuild, will the block, crank etc work if i use my external parts? is it totally different? what years do i need to locate? are outboard powerheads different than ones for jet boats? and finally for now what options would i have to go to a totally different engine and be able to connect to my lower unit?
sorry for many questions, this is my first jet boat experience, maybe my last. i/o i am ok with, and id probably be fine now if i had the original engine intact to work with. one thing is for sure id like to be able to identify what is actually in the boat now. i have tried casting number i have located on the lower mount, manifold, and even a part number on the two nice blue ignition coils, i cant seem to get any info to help
many thanks to anyone who has knowledge and experience as well as patience to help me thru this
mitch
mitch
