Re: How to Install a tachometer in a MD7B?
There should be four wires a red one, white, black and green. The red wire should be hooked up to a power source that is turned on when you turn the ignition on like the + terminal on your ignition switch. the black is ground, white is the light in the tach and the green should go to the negative side of the coil. Set the dial on the back of the tach for what ever amount of cylinders you have, then test it out.
