How to install a temp gauge for a 71 Evinrude 65 hp
Texas Heat
Would like to know how to do this. This motor does not have a tale tell and I want to monitor the engine temp. Thanks!
Texas Heat
Re: How to install a temp gauge for a 71 Evinrude 65 hp
Come on guys someone must know a way. This is an old motor and I bet the overheat buzzer is toast and I want to make sure I never cook the beast. Thanks!
Hooty
The hot ticket is not a temp gauge but a water pressure gauge. Install a new waterpump and water press gauge. Note water press at all engine speeds, (idle, fast idle, low mid-range, etc.) and then watch the water press like you would a temp gauge. Any deviation in press from whats normal warns of a problem before it overheats. Also monitors waterpump wear. My engine didn't have a tattle-tale either but it comes in the OMC water pressure gauge kit. Get the kit and we'll tell ya where to drill and tap the engine for the pressure tap fitting. Easy project.<br /><br />c/6<br /><br />Hooty
Texas Heat
Thanks Hooty. Guess it's time to break out the book and see what it takes to replace the impeller/water pump. I can see myself ^%#%^%Q this up!!!!!
