Guys during the process to make my 1960 40hp Johnson run as it should be I took off the flywheel , the armature plate , cleaned everything but I hit a bump under the armature plate is another plate with some markings and a keynotch kind of sign and two 0 punched on the plate now I don t know how to set this plate, the armature plate comes in the top of it, the crapy manual says nothing about this setting can you guys please shed some lite?
Does the keynotch has to align with the flywheel key?
I will attach some pics.
Thank you
Thank you
