how to lubricate coupling 4.3 penta i/o ?
donaldm
have a 2004 penta 4.3 sx. I see a grease fitting for the gimbal bearing but how do i grease the u joint and shaft splines (coupling) thanks don
bruceb58
Re: how to lubricate coupling 4.3 penta i/o ?
Pull the drive.
donaldm
i have a clymer shop manual which cover many detail, do you know of any ez to follow instruction for just the removal, grease and reinstall the drive? thanks again
bruceb58
donaldm
i see removing the drive has been coverd here before so that cancels my last post. but next question is there a best place to buy the oem volvo manuel?
bruceb58
Used to be able to get the from marine engine dot com. I would call them and ask. I got mine there.
iboats kills the link if you put in the actual link.
bruceb58
One thing you don't want to do is to follow the lifting by the "eye" instructions. I made myself a wood stand for the drive and later welded myself up a metal one.
Here is mine:
LouC bought one that is similar to mine:
http://forums.iboats.com/omc-i-o-inboard-engines-outdrives/homemade-sterndrive-stands-601461.html
post #5
Stumpy's Fabrication Works : Price List
Homemade ones in this thread including mine:
http://forums.iboats.com/mercruiser-i-o-inboard-engines-outdrives/building-outdrive-stand-49747.html
skydiveD30571
You can also find a free electronic version at www dot boatinfo dot no. I feel like I'm typing a craigslist ad.
mikeauton
Wooden out drive dolly is easy to make. Also the removal and refitting of the drive is pretty easy as long as you have your boat angled correctly on the trailer jack. You should also check the engine alignment whilst you have the drive off ;) Alignment bars are available on ebay for a few $
