Re: How to make an electromagnet?
it all works down to ampere turns - the more of both, the higher the magnetic force created. the problem is after a while the wire itself is becoming resistive so a thicker gauge may be required. Like xcuseme said, disconnecting the powersupply to the coil will yield unexpected results. The coil acts sort of like a capacitor is to voltage. Coils keep constant current going, when the power is disconnected, it'll use the built up magnetic force to continue the current running through it by building an electrical potential difference- upping the voltage across the coil until the current can continue, causing a big spark.<br />this is where you have to be carefull, a 1amp circuit @12v is not much, enough to give you a jolt if you hold it wrong. If you are thinking about lifting 350#s, youre going to be near 20amp or so, when the current is broken you will probably see voltages as high as 100,000 volts. @20 amps, in that instant when the coil discharges, if it discharges through you, you will die. No doubt about it. <br /><br />I hope I didnt discourage you, but the forces exerted by a collapsing magnetic forses can be greater then you might expect. I would however carry on with this project as it sounds like fun. I would start by buying a couple hundred foot roll of 18ga wire, you will need a good solid metal core, something that fits through the center of the roll. I would not want to switch it through a handheld switch, I would definately runit through a relay so that when you flip a switch a relay drops out and youre isolated from the coil circuit. I dont quite think 12Vdc is enough either but a good place to start, for supply I would use a bridge rectifier on a 110V house supply, but try low voltage first. <br />at work I have seen 15000 turn coils at 110v and it's not quite impressive to look at but does get to be quite strong, most circuits have a collapsing circuit across the coil to keep the sparks down, nothing just a bigger resistor and a diode.
