samo_ott
- Jun 18, 2006
- 5,125
So has anyone tried adding in a pee hole on the old 50's or 60's engines by drilling and tapping the water jacket? Then what would happen if you plugged up the exhaust outlet halfway up the leg? I believe the main reason for that outlet is to see the cooling water exit. But if you had a pee hole then you wouldn't need it. In theory.
Thus if you plugged it you would get rid of a lot of exhaust noise that also comes out through it and make it all go underwater like a thru hub'er. If you ever lean over and plug that hole with your thumb you will see what I mean. (I tried it 2 days ago on my 18hp and it is quieter) The only issue I could see is if when in reverse there's no exhaust relief by using this method and it could build up exhaust pressure.
Has anyone ever tried this? And comments, modifications or upgrades? It was just a thought I figured I'd throw out to the community.
