Re: How to pick the best prop ? ? ? ?
Pitch is a very important aspect of a boat, as important as having a beilge pump(no joke) <br /><br />you need to reach WOT(wide open throttle)<br />Most boats about 4000 rpms(check for your boat)<br /><br />If you like to ski , tow , or go slow a LOWER pitch will give you all of these.<br /><br />IF you like to Cruise , Go fast , Get better MPG<br />a HIGHER pith will give you all this.<br /><br />But like said father up in the post --TEST IT--<br /><br />You can read till you turn blue, but you really have to test a prop on YOUR boat.<br /><br />Two of the SAME props will run COMPLETELY different on Two DIFFERENT boats.<br /><br />Just match your WOT and you will have many happy days of boating.<br /><br />Do you have a Hydro-foil ? it will give you more TOP end , MPG ......
