How to plug livewell?
jeffb928
Hello, looking for ways to plug live-well so it could be used for storage? I bought a so called live-well plug from the marina but still getting small amount of water with both outside and inside plugged???
Silvertip
Re: How to plug livewell?
Will you ever use the livewell as a livewell? If not, put some sealer around the plug. If it still leaks there is a crack in livewell somewhere. Since the livewell is apparently filling from a below water line source which is normally at the back of the boat, plug it there.
