Hello- I've read some of the posts about replacing various seals in the Mercruiser outdrive and I have a question. My drive is leaking gear lube from the two seawater drain holes on either side. Which means the leak is inside the drive somewhere right? So pressure testing it will only show bubbles/a leak from those vent holes, correct? If that's the case it seems to me it won't actually tell me where the leak is coming from or which seals to replace. How would you guys approach isolating this and fixing it? Thanks for the help.
