How to prevent jack from seizing up? Gets submerged every launch
jakec
I’m on my second jack right now, and I just found out it’s seized when I went to take out my boat for the first time this year. The first jack lasted about 3 years, this one only lasted one summer. Unfortunately due to my trailer design, boat, and just the slope of the launches, I can’t avoid submerging the jack.
I’m about to buy another jack so I want this one to last. I paid for a high quality one (1500 lbs, $130) last spring and it’s already toast.
jakec
how and where? mine didn't seem to have a grease nipple or anything. And the top of the shaft is pressed on. Are you just packing by hand?
roscoe
Hmmm, So the trailer tongue gets submerged???
I’ve never seen a trailer tongue or Jack go under water.
Mount it further forward?
Extend the tongue then mount it further forward?
Buy a higher lift Jack and mount it above the trailer tongue?
Hard to suggest much more without a decent photo of the trailer tongue.
redneck joe
I can't figure out how I would get mine wet.
jlh3rd
Ensign
I'd have to see a picture of yours.
I don't have a grease nipple either.
There was a black cap that I would pop off and add grease if I wanted. I'd just stick the grease gun nozzle in and pump a few times.
Mine never goes under water either.
so this was the original on my '04 (?) trailer I bought used in 2016. It's been replaced because the marina broke the wheel and got me a brand new assembly 3 years ago. So it was 21+ years old and still good.
Earl Cordova
Mine gets wet when launching and the jack would last a year or two until I figured out
what part was filling up with water and drilled two 1/8" drain holes on the lowest section.
jakec
Ok, I probably need to be popping that top cap off and adding grease in addition to whatever comes from the factory. There already is one hole near the crank which may be for drainage, but obviously wasn’t enough to save it.
I only use a couple launches and they are all saltwater and just follow the slope of the beach. So for the folks saying they can’t imagine how it gets wet.. just imagine a low slope boat launch. The boat is flat bottomed and needs to go far in the water to float. Typically the water level is reaching just below the hitch receiver.
Jeff J
I have had to launch where I stepped into water getting out of the truck so pretty easy for me to imagine getting a jack wet. Shallow sloped boat ramp with long pontoon boat pretty much guarantees it. My rear axles have been completely submerged. I have never done a saltwater launch but have had some corrosion issues pop up on truck and trailer for needing to back in so far. For the record, I power load anything that has the power to do it (not illegal anywhere I have been).
I believe my current boat trailer manual says to drip some gear oil into it along the where shaft the handle is attached to. I will confirm that if I can find the paperwork that came with it.
airshot
Salt water is your enemy....if your going that deep, then your rear axle/ rotors/ drums are also getting salt in them. Can't imagine backing in that far, but I have saw some really bad ramps so it probably happens. My jack has a plastic cap on top that pops off so grease or heavy gear lube can be applied. On some, I have drilled holes into the shaft to squirt lube in there for lube. Most just runs out, but some stays in there. Your situation is very rare, so not many life experiences out there to help with your issue.
mike_i
This is the type of jack I have on my trailer. I pull the pin, remove the jack, toss it in my truck and all is well. The jack doesn't get wet and it can't disappear.
jakec
I would like a removable jack, I just need on with a wheel. I will look into that. I’m going to pop my jack open and see if it can’t be fixed first.
And seriously guys it’s I not that crazy to have a shallow sloped ramp lol. Within my normal boating area (central puget sound) there are 10+ launches near me and I would say 75% of them follow the contour of the beach. Some you’re lucky if it’s even paved past the median tide line. It’s a regional thing I suppose
Mc Tool
Maybe winding the jack up and down its full stroke every so often might redistribute what grease is in there.🙂
roscoe
I’ve beach launched many times. Once it was so shallow I was 150’ into the water before the water was deep enough to launch , but the water wasnt over the tongue or winch.
Don’t try this with out a tow truck standing by.
Stinnett21
There is one ramp on Lake Cumberland (KY) where I experience the same thing. I launch solo so I have to back in far enough to pull off without anyone dumping me in. The ramp is very shallow most of the year. This is of course fresh water. My jack has the black plastic cap so I can remove and it an lube the gears with fingers. Also while the cap is off I take spray lube (white lithium) and spray into the shaft with the jack positioned horizontally flipped both directions to lube the spiral shaft.
airshot
I do that at the end if each season, fill with grease and gear oil then crank the you know what out if it, all the way up and down for its winter storage. Come spring it is ready to go.
