How to put tilt/trim switch on control that doesn't have one
billdor
I'm replacing my Evinrude engine with a Suzuki 225. I bought a control handle for the Suzuki motor. It doesn't have a tilt/trim switch built in. Any ideas on how to put one on it would be great.
TIA
Bill
Frank Acampora
Re: How to put tilt/trim switch on control that doesn't have one
That will be difficult unless Suzuki used the same control handle for both versions. Basically you need to find a small enough M-O-M switch to fit (Radio Shack?), Cut an opening, run the wires down the handle, wrap around the hub to prevent breaking and hope it works.
It will probably be easier to buy a new control handle. By new, I mean new to you, but used. I know that in the US marine controls, a new switch costs 30-40 dollars. No telling what the whole handle would be.
pine island fred
I would avoid the generic momentary switches that you buy at radio shack or even the neat bubble packed that are sold at marine stores. They just dont hold up. My idea would be to purchase a bonified switch that goes on the side of the motor and mount it next to your controls. Might have to take a small file to dress up the hole to make it fit. Could probably get one here at iboats. does not matter what motor it is for, they are all about the same. FRED
ddrieck
These are great trim switches
You can get them here:
http://transom-jack.com/CMC-Waterproof-Tilt-Trim-or-Lift-Button-Switch--P1108874.aspx
billdor
ddrieck -
How does this fit into my new handle? I'd been looking for a new control handle for a bit more than a year. I found one for the Suzuki 225 but it doesn't have a built in tilt/trim switch.
Would I be able to safely rig something up using the trim switch you listed?
ddrieck
ddrieck -
Sorry for the confusion...
This switch mounts to the dash or any other flat surface be it in the bow area or the transom area.
I have One installed at the very nose of the bow to aid in loading and unloading off the trailer.
I have one installed on the inside of the transom splash well to aid in installing my transom saver. Makes things much easier when your all my yourself.
D
DJ
Guest
You are into customization here. The switch shown above is a very good one. Just mount it wherever you can.
The real answer is to get a Suzy handle with the switch. That should not be that hard.
If you can't do that, just mount a switch wherever is convenient. It is my experience that you do not use the switch as much if it is located somewhere else. Probably a good thing.
My Crownline has a trim switch, on the handle, I do not use that nearly as much as the trim plates switch, on the dash.
4JawChuck
