^^^ Simple is always the best. If for some reason racerone's method doesn't work, rent a slide hammer with a two jaw puller head. Bring your new bearing to the rental store to be sure the puller jaws will fit. Clamp the housing in a vise - use wood strips to protect the housing surfaces. Heat the housing and pull the old bearing. Follow racerone's freeze/heat instructions to plop your new bearing in.
