how to remove carburetor bowl from my 1994 force 70hp carburetor
daveinconyers
I need to remove the carburetor bowl from the carburetor on my 1994 force 70 hp engine. What is the proper way to remove it? Does it screw off or do I unscrew the bottom plug and then it comes off, or something else? I don't want to do something wrong and ruin something. Can anyone give me any advice? Thank you for any help you can offer!!
steveclv
Re: how to remove carburetor bowl from my 1994 force 70hp carburetor
You remove the center bolt and then gently tap the bowl with something soft if it's stuck into the seal. Use a new seal when reassembling.
