How to remove flywheel studs?
houstonnoob
How do you remove these studs with damaging them? I've plan to re use them or they'll need to be replace? I am swapping an engine, the new engine doesn't have them.
Also is this what everyone call a "one piece rear main seal" look like?
Re: How to remove flywheel studs?
Ayuh,.... That's a 1 pc. seal alright....
You put 2 nuts on a stud, tighten them Together, then turn out the stud, usin' the inner nut....
Don S
One note, go buy some regular nuts of the proper thread. The nuts that hold the coupler on are likely lock nuts, and you don't want to use them for stud removal.
houstonnoob
Thank you, got them all out.
Thank you, good suggestion. I did buy some regular nuts as you suggested.
