How to remove MerCruiser Alpha One Gen I drive gear from upper drive shaft?
nic420
nic420
How to remove MerCruiser Alpha One Gen I driven gear from upper drive shaft?
Bt Doctur
Depending if the gearset has been replaced , pull the horiz assembly out of the drive, remove the nut and washer, pull gear off yoke. If the gears have been replaced, remove the gear with a gear pullet. For the vert gear, the upper shaft is pressed out of the gear
http://www.boatfix.com/merc/Servmanl/6/6A3R3.PDF
