Re: how to remove old gelcoat repair patches??/
If the surface is smooth and looks the way you want it to, then you just need to sand it with 120 grit (or close to that) and spray some new matching gel coat over it, then sand and buff.
If these are old failing repairs then more work is needed, possibly grinding them out and starting over.
If epoxy was used to make the old repairs, then gel coat may not bond well to it, so more work is needed.
