How to remove the lower end on a 1954 Evinrude Big Twin 25 HP
pickupwizard
I'm trying to get the lower end off a 1954 Evinrude Big Twin 25 HP so I can use it on another project. The pre 1955 OMC motors do not have the side access panel to get at the rod shift connection. Someone suggested I have to remove the block in order to get at the shift rod connection. Seems like a lot of work just to remove the lower end. Peter
Joe Reeves
Look at the linkages halfway down between the long exhaust housing and the steering swivel bracket.
pickupwizard
Thanks for the suggestion. I think you are referring to the shift rod access panel on the left side of the exhaust tube that is common to OMC motors starting in 1955. The motor I have is a 1954 and it looks like the 1951-54 25 HP motors did not have this access panel.
F_R
On the contrary, there was a panel in 1953. If I remember correctly, it was eliminated in 1954 and they simply made it accessible without removing anything. Note that the connector is not inside the exhaust housing like 1955-up.
Posting 1953
Joe Reeves
On the contrary, there was a panel in 1953. If I remember correctly, it was eliminated in 1954 and they simply made it accessible without removing anything. Note that the connector is not inside the exhaust housing like 1955-up. Posting 1953
A much better explained note of what I meant.
