How to remove the spanner nut 45 hp Mercury lower unit
nmesllc
I need to replace the lower unit shaft oil seals but the spanner nut seems to be unwilling. Since it is plastic, worried about ruining the nut....any suggestions or idea on how to remove it. I don't have a spanner tool.
Thanks, Larry
sutor623
Re: How to remove the spanner nut 45 hp Mercury lower unit
Well you probably need to make or buy a spanner tool. Not worth cracking the gear case. We had to drill out a spanner nut one day but we got it out. It will be hard to get the new one in regardless, because it needs to be torqed down to spec. I've seen people using a hmer and screwdriver to spin the old nut off and new nut on, but I wouldn't try it.
