Im working on redoing interior on my 1990 four winns horizon 5.8 omc/cobra. I need to remove the throttle shifter lever to recover the side panel. I just the actual shifter handle off and assume the three Philips screws need to be removed to get it off. The screws are so tight you can't remove them without them trying to slip. Is there any trick to this or way around it? Thanks.
