how to remove trim motor 1998 Yamaha 225 salt water series
airwo.lf
I can get to 2 out of the 3 bolts how do you get the last bolt ?
99yam40
Re: how to remove trim motor 1998 Yamaha 225 salt water series
Probably will need to remove one of the transom brackets and then remove T&T unit.
Or pull motor off boat
brielly
Unscrew the manual release valve and tilt the engine up as far as it can go. Unbolt and remove the tilt and trim unit. A bit of wiggling/jiggling required but it will come out.Once its out replacing the trim motor is easy. I just did this yesterday and am in the process of doing the trim cylinders right now.
airwo.lf
thank you,
dam 3rd bolt makes for alot more work !!!!
