Captzoomie
- Aug 26, 2024
- 8
Hi, new here. I changed out the impeller on my 1978 mercury 1400 outboard, but am having trouble getting the water pump base out. Had water in my lower unit, so I figured I'd look at the oil seals under the water pump base, and change out that last gasket and O ring. I tried prying the base out by putting a small pry bar against the exhaust flange and rocking it from both sides. Also tried to use 2 screwdrivers to pry out from the side. Got nowhere in 2 hours. Are there any hidden bolts? (Didn't see a "Flush" bolt). Should I just jerk up on the driveshaft? Any other tips out there?
