Augoose
- Mar 21, 2010
- 1,223
All,
I did some searches but didn't come up with much, so I have a couple of questions...
My question pertains to the pads which run the length of the boat on the interior just below the gunwale.
I have wood under mine and it is rotted, so my plan was to remove them and pull the upholstery off as carefully as I can because its still in good shape. So my questions....
1) What are these long pads called?
2) There are other decorative inserts within the longer pads, different color of vinyl - are those made of wood as well and how are those secured to the pad typically? Some of those look ok so I'd like to save them if possible.
3) What is a good replacement product to put in the wood's place?
4) How are the pads that align the sides of the bow (back rest for passengers?) held in place?
3) Where is a good place to purchase replacement padding for all these pads and what type of padding is it? Marine special or same as other applications?
thanks all!
thanks all!
