HOW TO: Replacing Merc Alpha style impeller
Status
Not open for further replies.
Don S
Here are a couple of files I put together from pages from the OEM service manuals. It just puts the information in order making it easier to locate than sorting through the whole manual
MC-1 to Alpha I Up to and including 1990. http://forums.iboats.com/attachment.php?attachmentid=113737&stc=1&d=1316021371
For Alpha I Gen II Only 1991 to present, click on the second Attached Thumbnail highlighted it red.
  • A1 Impeller replace.pdf
  • A1G2 Impeller Replace.pdf
tschmidty
Re: HOW TO: Replacing Merc Alpha style impeller
Thank you for that, very helpful and much easier than searching and flipping through the full manual.
ken_23434
Good work Don.
If I only had that last picture and Note about a month ago... :redface:
nola mike
yup, first time i did it i stopped reading after the first section, when it seemed like it was done with the impeller--didn't see the actual "installation" part. thanks!
The 86
Thank you Don, appreciate the leg work.
Status
