Nautique93
- Nov 10, 2008
- 40
1983 Mercury 70 3 cyl. 9353189
I am struggling to line up to TDC, i can just about make out the 0 on the scale on the side of flywheel, but my manual says to set no.1 piston to .491 BTDC with dial gauge then line up flywheel so pointer is in line with that mark. My flywheel is rusted and i cant read the scale very well, and cant see the 491 mark the manual speaks of. Can i simply get no. 1 piston to TDC and line up flywheel so 0 degrees on gauge is in line with pointer? If so, what is the reason for setting .491 out with the gauge?
I now realise i shouldnt of removed the 6 flywheel bolts to change the stator, and got a puller instead so i could get it off with just the main nut, then i could of lined it up with the key on the shaft. I think i put it back on where it came off, but i am about to do a linc and sync and want to be sure.
If someone has a link to a picture showing the scale on the side of the flywheel that would be very helpful.
Thanks, Peter
Thanks, Peter
