Yacht Dr.
- Feb 26, 2005
- 5,581
There have been alot of questions about this..so I Resized some pics to post on the forum and tell you how I did this.
1. The only way you can restore Gel Properly is having enough Gel on there in the first place. If you have an older boat thats been sanded/buffed too many times you will not have enough material to buff out .. then its Paint or Re-gel time
2. Depending on the condition you may only have to rub (buff) with a polish. You may need a compound. You may have to sand/buff.
3. Your going to need a Rotary sander/polisher with a 5/8" arbor ( threaded thing at the end of the machine ).
4. Proper compound and/or polish ( this subject is kinda to each his own .. I use my stuff..he uses his stuff.. and you can use your stuff ). There are more productive/expensive compounds out there..but its not time for a debate.. use what works for you and your location.
5. Use MicroFiber or even baby swaddle blankets work Great ( I get those from the thrift stores for 10c each
). These materials seem to wipe off residue/compound better then just cotton rags.
6. Again depending on What condition your boats in..you may have to just Polish ( medium-low pressure ) .. or all the way up to Sand and Compound ( Medium-high pressure ).
7. Test test test .. start in one section till you get your compound/pressures just right..then start down the rest of the hull. Dont move to the next section untill you have a good Idea of what the boat needs. After about 3 sections you will narrow it down. You NEED Consistancy in your motion/pressure.
Here is one that I had to sand/buff. This thing was coated with .. erm.. something.. like MopN'Glow or something.
I had to sand ( DA dry ) with 600 and then Buff 2x .. But only compound .. No wax.
Hope this helps ..
YD.
Hope this helps ..
YD.
