hey yall.....
ok i got a boat...fiberglass --it had a motor inside with and outdrive...
i am using this boat for floating purposes only...it will not have any power to it.
what would be the best way to seal the outdrive hole...?
i was thinking a good 3/4 in ply soaked in epoxy resin for the outside.
and bolted to the same from the inside... and then once bolted together glass the outside to the hull covering the wood from the elements.
so in the end i would have a wood "seal" on the inside - fiberglass from the hull in the middle and then another wood "Seal" on the outside of the hull...all bolted together and glued using pl adhesive...
or should i go all fiberglass and be done with it.... sealing the outdrive hole from the outside of the hull only?
would yall have any other suggestions...
