bryceheinz
- May 30, 2012
- 29
I just pulled off my upper gear housing to replace the Bellows after they failed last trip out. We caught it in time and only ran about 20mins with them leaking. I noticed that the oil was milky but none of the seals are wet and all seem watertight. I just purchased this boat and installed a new engine so it has been sitting for about 2 years. I did not have any oil in the bellows and also did not have any oil leaking from prop area when running in a drum. Any ideas? Also where is the drain located for the lower unit and does it get filled from the dipstick hole or do I need to use the pump I used on my OMC?
