AQ125A/270, 16' Invader. My question is about setting the breaker point gap on my AQ125A. Manual says .040 mm or 0.157 in. Isn't this a starting place? <br /><br />I've been told that a dwell meter was the same as a tach like we already have on our guages and that a good way to do this was set the points at 0.157 (would 0.16 be ok?) start and check the rpm. Repeat this process until dwell gives you max rpm. <br /><br />Is there a better easier way?
