tie_one_on
- Oct 27, 2003
- 276
On a Prestolite, bolt on cap distibutor, how do you set dwell? If the manaul call for 29-33 degrees dwell and the points gap is 18 thousandths, and you set the points at that but the dwell is 25 degrees, what adjustments are made to correct this offset. The distributor plate has a triangler cut out for adjustments and the points a have an notch for adjustment how (besides trial and error do you adjust dwell)? I'm used to the pre 70's GM points distributors with the little windows for dwell adjustments. Before you flame me for mentioning automotive distributors on this site, I know the difference.
