I have just installed a used distributor, in my 85hp Merc.
I am awaiting a manual, and was wondering if someone could explain the base timing setting. The tag on the side of the motor says .172 BTDC , 27degrees. I see the gradations on the side of the motor.
There is also an arrow on the top of the distr. pulley.
I believe there is a "base timing setting" by lining up the timimg "dots" with the dist. pulley, and the spec is for timing advance adjustment. I am not interested in that yet ( although I believe that you bring the fly wheel to 27 Degrees BTDC and turn the dist. till it fires, with a meter on the spark plug and lock the "Spark Adv." screw in that position???)
Could someone help me set the "base timing"???
Thanks
