How to split this ?
orlandoclippertim
I have a 1959 Evinrude 35 horse. I think it was a brand new engine when something happened that it got some sand in the cylinders. Great shape except for that. Pistons stuck presantly in bores. have the powerhead off. Also head off.
Cant turn crank because pistons stuck. Tried bumping piston tops with wood block and dead blow. No-go.
I want to remove the bottom case so I can get the pistons out and try hoaning the bores to see how bad they are.
Got the bolts out of the edges and the 4 big bolts out. Tried bumping the crank to break the seal on the halves.
Dont want to do that too hard to bend the crank. Very little on the case to push on that wouldnt bend, distort or
otherwise ruin a perfect case. If I can get the bottom case off -- I can at least get the rods loose from the crank
and be better able to deal with the stuck pistons. When looking through the side ports-- I see one of the rings
looks broken because the end is sticking upward at an about 15 degree angle. That may prevent the piston from being withdrawn.
But how the heck to I get the seal between the case halves parted without bending or breaking something.
If I hit the crank with the pistons stuck--- I may be damaging the rod bearings and mains too. Is there a secret trick
here to split the case ?
Signed : stumped......
(tim)
The carburetor and reed valves are on the bench I hope.-----The tapered alignment dowels are out I hope.-----Make sure all the bolts are out and it should fall apart.
orlandoclippertim
Racer---- carb off--- reed box still on. I will take that off next. I remember that there are dowell pins around the edge of the case flange. But for some reason I was thinking that they are pressed in on one side and tapered on the other half----
so when you split they stay on one side......... am I mis-remembering ? can they come out BEFORE the case comes apart ? If YES----- do I just tap them with a flat punch --- and which direction...... if tapered they will only move one way right ?
Im hanging on your next words :)
Tim
Reed plate has to come off to find those last 2 bolts !!-----Drive out the taper pins., they go out by driving them towards where the carburetor was.
F_R
When you are ready to put it all back together, the taper pins go in before the bolts. They make sure everything is properly aligned.
